- Meridian, ID
I know what a regear is worth. I helped my brother regear his jeep. I may buy 37s and an extra set of rims and use em for trail use only until I can regear which means cut it all off.
Remember, 3rd is 1:1 and 4th is some horribly high 0.67:1 overdrive ratio.
Don't pick too much - I don't have much left
I take it you're tempted to throw that Chevy D44 under your truck? Well, don't worry... the anxiety passes after the first bracket is lopped off the frame![]()
5 cyl. With gm cat back
What ever happened to that Dana 44 IFS setup?
I already live in Okie-homa and don't have much faith in walking into O'Reilly's at ANY time of the day and finding much of what I need! But I get your point.Viable regearable solutions where I can walk into orielly at 8pm in Oklahoma and find a part is where it's at. Halfshafts R&P and seals need to be stockable items. Stub shafts would be nice but I'm not sure it's possible so those id have spares
outstanding! I may try that. I will probably hold onto the solid axle though, I may be moving my issues to the next weak point. If I am I may be able to atleast help others out who are more into moderate wheeling and want the I5 to not be so miserable with 35s. Junkyard has 50% this weekend too. I have work but if I can get it covered I would go.
I'm driving around with ~37s and they aren't half bad from what I've experienced in my cousins full size Bronco. I hate that truck (bronco). I gotta say that the leaf sprung SAS is a rough ride and as we all know my steering set up is less than desirable.
